ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphRelationshipTypeDescription Class / KnowledgeGraphRelationshipTypeDescription Constructor / KnowledgeGraphRelationshipTypeDescription Constructor(KnowledgeGraphRelationshipType)
The knowledge graph relationship type to use for the description object
    Construct a KnowledgeGraphRelationshipTypeDescription with the given ArcGIS.Core.Data.Knowledge.KnowledgeGraphRelationshipType. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function New( _
       ByVal relationshipType As KnowledgeGraphRelationshipType _
    public KnowledgeGraphRelationshipTypeDescription(
       KnowledgeGraphRelationshipType relationshipType
    Parameters
    relationshipType
    Exceptions
    ExceptionDescription
    Remarks
    The properties of the knowledge graph relationship type will be used to initialize the property description collection for the description object. If the knowledge graph relationship type contains a shape property then a shape description property will also be added (to the description object). The spatial reference of the shape description will default to the spatial reference of the knowledge graph used to initialize the ArcGIS.Core.Data.DDL.SchemaBuilder when using a shape description derived from a KnowledgeGraphRelationshipType.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
