ArcGIS.Core.Data.DDL.Knowledge Namespace / KnowledgeGraphRelationshipTypeDescription Class / KnowledgeGraphRelationshipTypeDescription Constructor / KnowledgeGraphRelationshipTypeDescription Constructor(String,KnowledgeGraphRelationshipType,ShapeDescription)
The name to use for the description object
The knowledge graph relationship type to use for the description object
The description to use for the shape. The spatial reference must match the spatial reference of the knowledge graph being used with the SchemaBuilder .
    Construct a KnowledgeGraphRelationshipTypeDescription with the given name, ArcGIS.Core.Data.Knowledge.KnowledgeGraphRelationshipType and shape definition. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    name
    relationshipType
    shapeDescription
    Exceptions
    ExceptionDescription
    name is invalid
    Remarks
    The name will be used for a new relationship type if the description object is used for purposes of creation. Otherwise, it will be used to identify an existing relationship type if the description object is used for the purposes of modify or delete.
    The properties of the knowledge graph relationship type will be used to initialize the property description collection for the description object. If the knowledge graph relationship type contains a shape property then a shape description property will also be added (to the description object). The spatial reference of the shape description parameter must match the spatial reference of the knowledge graph being used with the ArcGIS.Core.Data.DDL.SchemaBuilder. See ArcGIS.Core.Data.Knowledge.KnowledgeGraph.GetSpatialReference.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
