ArcGIS.Desktop.Core Namespace / LayoutOptions Class / SetGuideColor Method
The new guide color.
Example
    Sets the layout guide color. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetGuideColor( _
       ByVal color As CIMColor _
    public void SetGuideColor(
       CIMColor color
    Parameters
    color
    Example
    Set LayoutOptions
      //keep graphic element insert tool active
      ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
      //no warning when deleting a map frame results in other elements being deleted
      ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
      //path to .pagx files used as templates
      ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
      var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
      // set guide color
      //Note: Must be on QueuedTask.Run
      ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
    Requirements
    ArcGIS Pro version: 3.4 or higher.
