ArcGIS.Desktop.Core Namespace / SelectionOptions Class / SetEnableClickTolerance Method
The value indicating whether click tolerance is enabled.
    SetEnableClickTolerance Method (SelectionOptions)
    Sets the value indicating whether click tolerance is enabled. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetEnableClickTolerance( _
       ByVal enable As Boolean _
    public void SetEnableClickTolerance(
       bool enable
    Parameters
    enable
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.4 or higher.
