ArcGIS.Desktop.Core Namespace / SelectionOptions Class / SetSelectionFillColor Method
The selection fill color.
    Sets the selection fill color. Use this in conjunction with SetSelectionFillIsHatched to set solid or hatched fills as appropriate. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetSelectionFillColor( _
       ByVal color As CIMColor _
    public void SetSelectionFillColor(
       CIMColor color
    Parameters
    color
    Exceptions
    ExceptionDescription
    Remarks
    Specify a null value for no color to be applied to polygon interiors.
    Requirements
    ArcGIS Pro version: 3.4 or higher.
