ArcGIS.Desktop.Core Namespace / SelectionOptions Class / SetSelectionTolerance Method
The search tolerance in device units.
    SetSelectionTolerance Method (SelectionOptions)
    Sets the search tolerance in device units. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetSelectionTolerance( _
       ByVal tolerance As Integer _
    public void SetSelectionTolerance(
       int tolerance
    Parameters
    tolerance
    Exceptions
    ExceptionDescription
    Requirements
    ArcGIS Pro version: 3.4 or higher.
