ArcGIS.Core.CIM Namespace / CIMLayerDocument Class / LayerDefinitions Property
Example
    LayerDefinitions Property (CIMLayerDocument)
    Gets or sets the layer definitions in the layer document.
    Syntax
    public CIMDefinition[] LayerDefinitions {get; set;}
    Public Property LayerDefinitions As CIMDefinition()
    Remarks
    This collection contains the definitions for the top-level layers and all sublayers.
    Example
    Create layer from a lyrx file
      await QueuedTask.Run(() =>
        var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
      //modifying its renderer symbol to red
      var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
      cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
      //optionally save the updates out as a file
      lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
      //get a json representation of the layer document and you want store away...
      var aJSONString = lyrDocFromLyrxFile.AsJson();
      //... and load it back when needed
      lyrDocFromLyrxFile.Load(aJSONString);
      //create a layer and add it to a map
        var lcp = new LayerCreationParams(cimLyrDoc);
        var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Apply Symbology to a layer from a Layer file
      IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
        .Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
      var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
      foreach (var featureLayerToSymbolize in featureLayers)
        //Get the Layer Document from the lyrx file
        var lyrDocFromLyrxFile = new LayerDocument(layerFile);
        //Get the renderer from the layer file
        var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
        //Apply the renderer to the feature layer
        //Note: If working with a raster layer, use the SetColorizer method.
        featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
    Requirements
