ArcGIS.Core.Data.Realtime Namespace / RealtimeFeature Class
Members Example
    Represents a feature in a RealtimeFeatureClass returned by RealtimeCursor
    Object Model
    RealtimeFeature ClassGeometry Class
    Syntax
    Public NotInheritable Class RealtimeFeature
       Inherits RealtimeRow
       Implements System.IDisposable
    public sealed class RealtimeFeature : RealtimeRow, System.IDisposable
    Example
    Subscribe to Streaming Data
      //Note: with feature class we can also use a System Task to subscribe and
      //process rows
      // Note: call within QueuedTask.Run()
        // or var rfc = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass
        using RealtimeFeatureClass rfc = streamLayer.GetFeatureClass();
        //non-recycling cursor - 2nd param "false"
        //subscribe, pre-existing rows are not searched
        using RealtimeCursor rc = rfc.Subscribe(qfilter, false);
        SpatialQueryFilter spatialFilter = new SpatialQueryFilter();
        //waiting for new features to be streamed
        //default is no cancellation
        while (rc.WaitForRowsAsync().Result)
          while (rc.MoveNext())
            using (var row = rc.Current)
              switch (row.GetRowSource())
                case RealtimeRowSource.EventInsert:
                  //getting geometry from new events as they arrive
                  Polygon poly = ((RealtimeFeature)row).GetShape() as Polygon;
                  //using the geometry to select features from another feature layer
                  spatialFilter.FilterGeometry = poly;//project poly if needed...
                  featureLayer.Select(spatialFilter);
                  continue;
                default:
                  continue;
        //row cursor is disposed. row cursor is unsubscribed
    Search Existing Data and Subscribe for Streaming Data
      //Note we can use System Task with the Realtime feature class
      //for subscribe
        using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false);
        //default is no cancellation - use await in async method
          //pre-existing rows will be retrieved that were searched
            using RealtimeRow row = rc.Current;
            var row_source = row.GetRowSource();
            switch (row_source)
              case RealtimeRowSource.EventDelete:
                //TODO - handle deletes
                break;
                //TODO handle inserts
                break;
              case RealtimeRowSource.PreExisting:
                //TODO handle pre-existing rows
                break;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Realtime.RealtimeRow
             ArcGIS.Core.Data.Realtime.RealtimeFeature
    Requirements
