ArcGIS.Core.Data.Realtime Namespace / RealtimeFeatureClass Class
Members Example
    Represents a real-time table with a spatial column.
    Object Model
    RealtimeFeatureClass ClassInsertCursor ClassFeature ClassRowBuffer ClassUpdateCursor ClassDifferenceCursor ClassTable ClassRealtimeDatastore ClassRealtimeFeatureClassDefinition ClassEnvelope ClassFeatureDataset ClassJoin ClassRelationshipClass ClassRowCursor ClassRealtimeCursor ClassSelection ClassRowCursor ClassRealtimeCursor ClassContingencyValidationResult Class
    Syntax
    Public NotInheritable Class RealtimeFeatureClass
       Inherits ArcGIS.Core.Data.FeatureClass
       Implements System.IDisposable
    public sealed class RealtimeFeatureClass : ArcGIS.Core.Data.FeatureClass, System.IDisposable
    Remarks
    Streaming does not start automatically. Call StartStreaming explicitly to start receiving feature stream.
    Example
    Connect to a real-time feature class from a real-time datastore
      var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
      // Note: call within QueuedTask.Run()
        var realtimeServiceConProp = new RealtimeServiceConnectionProperties(
                                       new Uri(url),
                                       RealtimeDatastoreType.StreamService
        using var realtimeDatastore = new RealtimeDatastore(realtimeServiceConProp);
        //A Realtime data store only contains **one** Realtime feature class (or table)
        var name = realtimeDatastore.GetTableNames().First();
        using (RealtimeFeatureClass realtimeFeatureClass = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass)
          //feature class, by default, is not streaming (opposite of the stream layer)
          realtimeFeatureClass.StartStreaming();
          //TODO use the feature class
    Check the Realtime Feature Class is Track Aware
        using var rfc = streamLayer.GetFeatureClass();
        using var rfc_def = rfc.GetDefinition();
        if (rfc_def.HasTrackIDField())
          //Track aware
    Get the Track Id Field from the Realtime Feature class
        using (var rfc = streamLayer.GetFeatureClass())
        using (var rfc_def = rfc.GetDefinition())
            var fld_name = rfc_def.GetTrackIDField();
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.CoreObjectsBase
          ArcGIS.Core.Data.Dataset
             ArcGIS.Core.Data.Table
                   ArcGIS.Core.Data.Realtime.RealtimeFeatureClass
    Requirements
