ArcGIS.Core.Data.Realtime Namespace / RealtimeFeatureClass Class / StartStreaming Method
Example
    StartStreaming Method (RealtimeFeatureClass)
    Sets the feature class to a state where it starts listening to broadcasts from a real-time service This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub StartStreaming()
    public void StartStreaming()
    Exceptions
    ExceptionDescription
    Remarks
    When you create a RealtimeFeatureClass, it does not start listening by default. You need to call this function explicitly.
    Example
    Connect to a real-time feature class from a real-time datastore
      var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
      // Note: call within QueuedTask.Run()
        var realtimeServiceConProp = new RealtimeServiceConnectionProperties(
                                       new Uri(url),
                                       RealtimeDatastoreType.StreamService
        using var realtimeDatastore = new RealtimeDatastore(realtimeServiceConProp);
        //A Realtime data store only contains **one** Realtime feature class (or table)
        var name = realtimeDatastore.GetTableNames().First();
        using (RealtimeFeatureClass realtimeFeatureClass = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass)
          //feature class, by default, is not streaming (opposite of the stream layer)
          realtimeFeatureClass.StartStreaming();
          //TODO use the feature class
    Requirements
