ArcGIS.Core.Data.Realtime Namespace / RealtimeFeature Class / Item Property
    Item Property (RealtimeFeature)
    Gets and sets the value of a field given its index position. This method must be called on the MCT. Use QueuedTask.Run.
    Overload List
    OverloadDescription
    Gets and sets the value of a field given its attribute name or alias name. This indexer can be called on any thread. (Inherited from ArcGIS.Core.Data.Realtime.RealtimeRow)
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    index corresponds to a shape field index and the type of shape (i.e., geometry) is not supported.
    Remarks
    The index for the fields is zero based. If the ArcGIS.Core.Data.Field.FieldType corresponding to the specified field index is ArcGIS.Core.Data.FieldType.Blob, the value will be System.IO.MemoryStream.
    Requirements
