Public Function GetRowSource() As RealtimeRowSource
public RealtimeRowSource GetRowSource()
Return Value
A value of RealtimeRowSource specifying the source of this real-time row.
| Exception | Description |
| ArcGIS.Core.Data.Exceptions.GeodatabaseException | A geodatabase-related exception has occurred. |
// Note: call within QueuedTask.Run()
//query filter can be null to search and retrieve all rows
//true means recycling cursor
using (var rc = streamLayer.SearchAndSubscribe(qfilter, true))
//waiting for new features to be streamed
//default is no cancellation
while (rc.WaitForRowsAsync().Result)
while (rc.MoveNext())
using (var row = rc.Current)
//determine the origin of the row event
switch (row.GetRowSource())
case RealtimeRowSource.PreExisting:
//pre-existing row at the time of subscribe
continue;
case RealtimeRowSource.EventInsert:
//row was inserted after subscribe
continue;
case RealtimeRowSource.EventDelete:
//row was deleted after subscribe
continue;
}//row cursor is disposed. row cursor is unsubscribed
//....or....
//Use the feature class instead of the layer
using var rfc = streamLayer.GetFeatureClass();
//non-recycling cursor - 2nd param "false"
using (RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false))
//etc
//Recycling cursor - 2nd param "true"
//or streamLayer.Subscribe(qfilter, true) to just subscribe
//auto-cancel after 20 seconds
var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
//catch TaskCanceledException
try
while (rc.WaitForRowsAsync(cancel.Token).Result)
//check for row events
using var row = rc.Current;
//etc
catch (TaskCanceledException)
//Handle cancellation as needed
cancel.Dispose();
//Note: with feature class we can also use a System Task to subscribe and
//process rows
// or var rfc = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass
using RealtimeFeatureClass rfc = streamLayer.GetFeatureClass();
//subscribe, pre-existing rows are not searched
using RealtimeCursor rc = rfc.Subscribe(qfilter, false);
SpatialQueryFilter spatialFilter = new SpatialQueryFilter();
//getting geometry from new events as they arrive
Polygon poly = ((RealtimeFeature)row).GetShape() as Polygon;
//using the geometry to select features from another feature layer
spatialFilter.FilterGeometry = poly;//project poly if needed...
featureLayer.Select(spatialFilter);
continue;
default:
continue;
//Note we can use System Task with the Realtime feature class
//for subscribe
using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false);
//default is no cancellation - use await in async method
//pre-existing rows will be retrieved that were searched
using RealtimeRow row = rc.Current;
var row_source = row.GetRowSource();
switch (row_source)
//TODO - handle deletes
break;
//TODO handle inserts
break;
//TODO handle pre-existing rows
break;
using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, true);
try
// Use await in async method
using RealtimeRow record = rc.Current;
// Process the record
cancel.Dispose();
