ArcGIS.Core.Data.Realtime Namespace / RealtimeTable Class / GetExpirationMaxAge Method
    GetExpirationMaxAge Method (RealtimeTable)
    Gets the expiration maximum age for rows. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public TimeSpan GetExpirationMaxAge()
    Public Function GetExpirationMaxAge() As TimeSpan
    Return Value
    The System.TimeSpan indicating rows older than this value are being removed.
    Exceptions
    ExceptionDescription
    Remarks
    When RealtimeTableDefinition.HasTrackIDField is true, it represents maximum age within each track. Previous observations that are older than the maximum expiration age comparing to the latest observation in the same track, get removed.
    When RealtimeTableDefinition.HasTrackIDField is false, rows older than the maximum expiration age, comparing to the current time, get removed.
    Requirements
