ArcGIS.Core.Data.Realtime Namespace / RealtimeTable Class / SetExpirationMaxCount Method
The values indicating how many rows will be stored at any given time.
    SetExpirationMaxCount Method (RealtimeTable)
    Gets the expiration maximum row count. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetExpirationMaxCount(
       ulong expirationMaxCount
    Public Sub SetExpirationMaxCount( _
       ByVal expirationMaxCount As ULong _
    Parameters
    expirationMaxCount
    Exceptions
    ExceptionDescription
    Remarks
    You need to set SetExpirationMethod to RowExpirationMethod.MaxCount to get that in effect.
    When RealtimeTableDefinition.HasTrackIDField is true, it represents total number of rows within each track.
    When RealtimeTableDefinition.HasTrackIDField is false, it represents total number of rows.
    If you don't want any rows removed, set this value to 0.
    It uses FIFO method - the first one comes in is the first one to be removed.
    Requirements
