ArcGIS.Core.Data.UtilityNetwork.Trace Namespace / IsolationTracer Class
Members
    The IsolationTracer class identifies features that can isolate a specific section of a network
    Object Model
    IsolationTracer ClassUtilityNetwork Class
    Syntax
    Public Class IsolationTracer
       Inherits Tracer
    public class IsolationTracer : Tracer
    Remarks
    • The isolation trace requires that at least one Filter barrier is set in the TraceConfiguration. Typically this filter identifies those features that isolate the section of network (e.g., valves).
    • The TraceConfiguration.IncludeIsolatedFeatures property can be used with the isolation trace to include the isolated features with the trace results. If set to False, the default, only the isolating features (e.g., valves) are returned.
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.Data.UtilityNetwork.Trace.Tracer
          ArcGIS.Core.Data.UtilityNetwork.Trace.IsolationTracer
    Requirements
