ArcGIS.Core.Geometry Namespace / IGeometryEngine Interface / ConstructMultipatchExtrude Method
The base geometry.
The Z offset.
Example
    ConstructMultipatchExtrude Method (IGeometryEngine)
    Creates a multipatch from the input polygon or polyline.
    Syntax
    Function ConstructMultipatchExtrude( _
       ByVal multipart As Multipart, _
       ByVal zOffset As Double _
    ) As Multipatch
    Multipatch ConstructMultipatchExtrude(
       Multipart multipart,
       double zOffset
    Parameters
    multipart
    The base geometry.
    zOffset
    The Z offset.
    Return Value
    Returns the multipatch.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The geometry is not Z-Aware.
    Remarks
    Creates a multipatch from a base geometry by extruding the base geometry along the Z-axis by a given offset factor. The base Z-values of the geometry are preserved and the top Z-values are calculated as an offset of each point in the base geometry. The resulting extrusion is parallel to the XY-plane if and only if the base geometry is parallel to the XY-plane.
    Example
    Construct Multipatch via Extrusion of Polygon or Polyline
      // build a polygon
      string json = "{\"hasZ\":true,\"rings\":[[[0,0,0],[0,1,0],[1,1,0],[1,0,0],[0,0,0]]],\"spatialReference\":{\"wkid\":4326}}";
      Polygon polygonNew = PolygonBuilderEx.FromJson(json);
      // extrude the polygon by an offset to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrude(polygon, 2);
      // a different polygon
      json = "{\"hasZ\":true,\"rings\":[[[0,0,1],[0,1,2],[1,1,3],[1,0,4],[0,0,1]]],\"spatialReference\":{\"wkid\":4326}}";
      polygon = PolygonBuilderEx.FromJson(json);
      // extrude between z values to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeFromToZ(polygon, -10, 20);
      // extrude along the axis defined by the coordinate to create a multipatch
      Coordinate3D coord = new Coordinate3D(10, 18, -10);
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongVector3D(polygon, coord);
      // build a polyline
      json = "{\"hasZ\":true,\"paths\":[[[400,800,1000],[800,1400,1500],[1200,800,2000],[1800,1800,2500],[2200,800,3000]]],\"spatialReference\":{\"wkid\":3857}}";
      Polyline polylineNew = PolylineBuilderEx.FromJson(json);
      // extrude to a specific z value to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeToZ(polyline, 500);
      Coordinate3D fromCoord = new Coordinate3D(50, 50, -500);
      Coordinate3D toCoord = new Coordinate3D(200, 50, 1000);
      // extrude between two coordinates to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongLine(polyline, fromCoord, toCoord);
    Requirements
