ArcGIS.Core.Geometry Namespace / CompositeGeographicTransformation Class / ToJson Method
Example
    ToJson Method (CompositeGeographicTransformation)
    Returns the JSON representation of this transformation.
    Syntax
    Public Overrides NotOverridable Function ToJson() As String
    public override string ToJson()
    Return Value
    JSON string
    Example
    Create Composite Geographic Transformation
      // Create singleton from wkid
      CompositeGeographicTransformation cgt =
          ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(108272);
      int count = cgt.Count;    // count = 1
      IList<GeographicTransformation> gts = cgt.Transformations
                                      as IList<GeographicTransformation>;
      gts.Add(ArcGIS.Core.Geometry.GeographicTransformation.Create(1437, false));
      count = cgt.Count;        // count = 2
      // create from an enumeration
      CompositeGeographicTransformation another_cgt =
                    ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(gts);
      GeographicTransformation gt0 = another_cgt[0];
      GeographicTransformation gt1 = another_cgt[1];
      // get the inverse
      CompositeGeographicTransformation inversed_cgt = another_cgt.GetInverse() as CompositeGeographicTransformation;
      // inversed_cgt[0] is same as gt1
      // inversed_cgt[1] is same as gt0
      var wkt = gt0.Wkt;
      // create from string
      CompositeGeographicTransformation third_cgt =
         ArcGIS.Core.Geometry.CompositeGeographicTransformation.Create(wkt, gt0.IsForward);
      count = third_cgt.Count;        // count = 1
      // create from josn
      string json = cgt.ToJson();
      CompositeGeographicTransformation joson_cgt =
        DatumTransformation.CreateFromJson(json) as CompositeGeographicTransformation;
    Requirements
