Public NotInheritable Class CompositeGeographicTransformation Inherits DatumTransformation
public sealed class CompositeGeographicTransformation : DatumTransformation
// methods need to run on the MCT
ArcGIS.Desktop.Framework.Threading.Tasks.QueuedTask.Run(() =>
// find the first transformation used between spatial references 4267 and 4326
SpatialReference sr4267 =
SpatialReferenceBuilder.CreateSpatialReference(4267);
SpatialReference sr4326 = SpatialReferences.WGS84;
List<ProjectionTransformation> transformations =
ProjectionTransformation.FindTransformations(sr4267, sr4326);
// transformations.Count = 1
ProjectionTransformation projTrans = transformations[0];
CompositeGeographicTransformation compositeGT =
projTrans.Transformation as CompositeGeographicTransformation;
GeographicTransformation gt = compositeGT[0];
// gt.Wkid = 15851
// gt.Name = "NAD_1927_To_WGS_1984_79_CONUS"
// gt.IsForward = true
// find the first five transformation used between spatial references 4267 and 4326
transformations = ProjectionTransformation.FindTransformations(
sr4267, sr4326, numResults: 5);
// transformations.Count = 5
compositeGT = projTrans.Transformation as CompositeGeographicTransformation;
// compositeGT.Count = 1
// compositeGT[0].Wkid = 15851
// compositeGT[0].Name = "NAD_1927_To_WGS_1984_79_CONUS"
// compositeGT[0].IsForward = true
projTrans = transformations[1];
// compositeGT[0].Wkid = 1173
// compositeGT[0].Name = "NAD_1927_To_WGS_1984_4"
projTrans = transformations[2];
// compositeGT[0].Wkid = 1172
// compositeGT[0].Name = "NAD_1927_To_WGS_1984_3"
projTrans = transformations[3];
// compositeGT.Count = 2
// compositeGT[0].Wkid = 1241
// compositeGT[0].Name = "NAD_1927_To_NAD_1983_NADCON"
// compositeGT[1].Wkid = 108190
// compositeGT[1].Name = "WGS_1984_(ITRF00)_To_NAD_1983"
// compositeGT[1].IsForward = false
projTrans = transformations[4];
// compositeGT[1].Wkid = 1515
// compositeGT[1].Name = "NAD_1983_To_WGS_1984_5"
// compositeGT[1].IsForward = true
// references 4267 and 4326 within Alaska
// Alaska
Envelope envelope = EnvelopeBuilderEx.CreateEnvelope(-161, 61, -145, 69);
sr4267, sr4326, envelope);
// compositeGT[0].Wkid = 1243
// compositeGT[0].Name = "NAD_1927_To_NAD_1983_Alaska"
// find the first geographic transformation used between two spatial references with VCS (use vertical = false)
SpatialReference inSR =
SpatialReferenceBuilder.CreateSpatialReference(4269, 115702);
SpatialReference outSR =
SpatialReferenceBuilder.CreateSpatialReference(4326, 3855);
// Even though each spatial reference has a VCS,
// vertical = false should return geographic transformations.
transformations = ProjectionTransformation.FindTransformations(inSR, outSR);
// compositeGT[0].Wkid = 108190
// compositeGT[0].Name = ""WGS_1984_(ITRF00)_To_NAD_1983"
// compositeGT[0].IsForward = false
// find the first vertical transformation used between two spatial references with VCS (use vertical = true)
transformations =
inSR, outSR, vertical: true);
CompositeHVDatumTransformation compositeHV =
projTrans.Transformation as CompositeHVDatumTransformation;
// compositeHV.Count = 2
// compositeHV[0].Wkid = 1188
// compositeHV[0].Name = "NAD_1983_To_WGS_1984_1"
// compositeHV[0].IsForward = true
// compositeHV[1].Wkid = 110019
// compositeHV[1].Name = "WGS_1984_To_WGS_1984_EGM2008_2.5x2.5_Height"
// compositeHV[1].IsForward = true
System.Object
ArcGIS.Core.Geometry.DatumTransformation
ArcGIS.Core.Geometry.CompositeGeographicTransformation
