ArcGIS.Core.Geometry Namespace / GeometryEngine Class / ConstructMultipatchExtrudeFromToZ Method
The base geometry.
The Z-value of the base.
The Z-value of the top.
Example
    ConstructMultipatchExtrudeFromToZ Method (GeometryEngine)
    Creates a multipatch from the input polygon or polyline.
    Syntax
    Public Function ConstructMultipatchExtrudeFromToZ( _
       ByVal multipart As Multipart, _
       ByVal fromZ As Double, _
       ByVal toZ As Double _
    ) As Multipatch
    public Multipatch ConstructMultipatchExtrudeFromToZ(
       Multipart multipart,
       double fromZ,
       double toZ
    Parameters
    multipart
    The base geometry.
    fromZ
    toZ
    Return Value
    Returns the multipatch.
    Exceptions
    ExceptionDescription
    Geometry is null or empty.
    The geometry is not Z-Aware.
    Remarks
    Creates a multipatch from a base geometry by extruding the base geometry along the Z-axis from a given fromZ input to a given toZ input. The base Z-values of the geometry are uniformly set to the fromZ input and the top Z-values are uniformly set to the toZ value. The resulting extrusion is always parallel to the xy-plane on both the base and the top.
    Example
    Construct Multipatch via Extrusion of Polygon or Polyline
      // build a polygon
      string json = "{\"hasZ\":true,\"rings\":[[[0,0,0],[0,1,0],[1,1,0],[1,0,0],[0,0,0]]],\"spatialReference\":{\"wkid\":4326}}";
      Polygon polygonNew = PolygonBuilderEx.FromJson(json);
      // extrude the polygon by an offset to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrude(polygon, 2);
      // a different polygon
      json = "{\"hasZ\":true,\"rings\":[[[0,0,1],[0,1,2],[1,1,3],[1,0,4],[0,0,1]]],\"spatialReference\":{\"wkid\":4326}}";
      polygon = PolygonBuilderEx.FromJson(json);
      // extrude between z values to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeFromToZ(polygon, -10, 20);
      // extrude along the axis defined by the coordinate to create a multipatch
      Coordinate3D coord = new Coordinate3D(10, 18, -10);
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongVector3D(polygon, coord);
      // build a polyline
      json = "{\"hasZ\":true,\"paths\":[[[400,800,1000],[800,1400,1500],[1200,800,2000],[1800,1800,2500],[2200,800,3000]]],\"spatialReference\":{\"wkid\":3857}}";
      Polyline polylineNew = PolylineBuilderEx.FromJson(json);
      // extrude to a specific z value to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeToZ(polyline, 500);
      Coordinate3D fromCoord = new Coordinate3D(50, 50, -500);
      Coordinate3D toCoord = new Coordinate3D(200, 50, 1000);
      // extrude between two coordinates to create a multipatch
      multipatch = GeometryEngine.Instance.ConstructMultipatchExtrudeAlongLine(polyline, fromCoord, toCoord);
    Requirements
