GetPatchMaterialIndex Method
Gets the index of the material for the specified patch (part).
Public Function GetPatchMaterialIndex( _
ByVal As Integer _
) As Integer
public int GetPatchMaterialIndex(
int
Parameters
- patchIndex
- The index of the patch. Must be greater than or equal to zero and less than PartCount.
Return Value
The index into the materials array of the multipatch for the patch.
Get the texture image of a multipatch
int patchIndex = 0;
int materialIndex = multipatch.GetPatchMaterialIndex(patchIndex);
if (!multipatch.IsMaterialTextured(materialIndex))
return;
TextureCompressionType compressionType =
multipatch.GetMaterialTextureCompressionType(materialIndex);
string ext = compressionType == TextureCompressionType.CompressionJPEG ? ".jpg" : ".dat";
byte[] textureBuffer = multipatch.GetMaterialTexture(materialIndex);
Stream imageStream = new MemoryStream(textureBuffer);
System.Drawing.Image image = System.Drawing.Image.FromStream(imageStream);
image.Save(@"C:\temp\myImage" + ext);
Get the material properties of a multipatch
if (multipatch.HasMaterials)
int patchIndex = 0;
// Get the material index for the specified patch.
System.Windows.Media.Color color = multipatch.GetMaterialColor(materialIndex);
int tranparencyPercent = multipatch.GetMaterialTransparencyPercent(materialIndex);
bool isBackCulled = multipatch.IsMaterialCullBackFace(materialIndex);
if (multipatch.IsMaterialTextured(materialIndex))
int bpp = multipatch.GetMaterialTextureBytesPerPixel(materialIndex);
int columnCount = multipatch.GetMaterialTextureColumnCount(materialIndex);
int rowCount = multipatch.GetMaterialTextureRowCount(materialIndex);
