ArcGIS.Core.Geometry Namespace / Multipatch Class / GetPatchTextureCoordinates Method
The index of the patch. Must be greater than or equal to zero and less than PartCount.
The collection into which the coordinates are copied. If textureCoordinates is null, then a list is allocated.
Example
    Gets a collection of coordinates representing the texture coordinates for the specified patch (part).
    Syntax
    Public Sub GetPatchTextureCoordinates( _
       ByVal patchIndex As Integer, _
       ByRef textureCoordinates As ICollection(Of Coordinate2D) _
    public void GetPatchTextureCoordinates(
       int patchIndex,
       ref ICollection<Coordinate2D> textureCoordinates
    Parameters
    patchIndex
    textureCoordinates
    Exceptions
    ExceptionDescription
    The patch index must be >= 0.
    The patch index must be less than the number of patches (parts) in the multipatch.
    Example
    Multipatch Properties
      int patchIndex = 0;
      // standard geometry properties
      bool hasZ = multipatch.HasZ;
      bool hasM = multipatch.HasM;
      bool hasID = multipatch.HasID;
      bool isEmpty = multipatch.IsEmpty;
      var sr = multipatch.SpatialReference;
      // number of patches (parts)
      int patchCount = multipatch.PartCount;
      // number of points
      int pointCount = multipatch.PointCount;
      // retrieve the points as MapPoints
      ReadOnlyPointCollection pointsMultipatch = multipatch.Points;
      // or as 3D Coordinates
      IReadOnlyList<Coordinate3D> coordinates = multipatch.Copy3DCoordinatesToList();
      // multipatch materials
      bool hasMaterials = multipatch.HasMaterials;
      int materialCount = multipatch.MaterialCount;
      // multipatch textures
      bool hasTextures = multipatch.HasTextures;
      int textureVertexCount = multipatch.TextureVertexCount;
      // normals
      bool hasNormals = multipatch.HasNormals;
      // properties for an individual patch (if multipatch.PartCount > 0)
      int patchPriority = multipatch.GetPatchPriority(patchIndex);
      PatchType patchType = multipatch.GetPatchType(patchIndex);
      // patch points
      int patchPointCount = multipatch.GetPatchPointCount(patchIndex);
      int pointStartIndex = multipatch.GetPatchStartPointIndex(patchIndex);
      // the patch Points are then the points in multipatch.Points from pointStartIndex to pointStartIndex + patchPointCount
      // if the multipatch has materials
      if (hasMaterials)
        // does the patch have a material?
        //   materialIndex = -1 if the patch does not have a material;
        //   0 <= materialIndex < materialCount if the patch does have materials
        int materialIndex = multipatch.GetPatchMaterialIndex(patchIndex);
        // properties for an individual material (if multipatch.MaterialCount > 0)
        var color = multipatch.GetMaterialColor(materialIndex);
        var edgeColor = multipatch.GetMaterialEdgeColor(materialIndex);
        var edgeWidth = multipatch.GetMaterialEdgeWidth(materialIndex);
        var shiness = multipatch.GetMaterialShininess(materialIndex);
        var percent = multipatch.GetMaterialTransparencyPercent(materialIndex);
        var cullBackFace = multipatch.IsMaterialCullBackFace(materialIndex);
        // texture properties
        bool isTextured = multipatch.IsMaterialTextured(materialIndex);
        if (isTextured)
          int columnCount = multipatch.GetMaterialTextureColumnCount(materialIndex);
          int rowCount = multipatch.GetMaterialTextureRowCount(materialIndex);
          int bpp = multipatch.GetMaterialTextureBytesPerPixel(materialIndex);
          TextureCompressionType compressionType = multipatch.GetMaterialTextureCompressionType(materialIndex);
          var texture = multipatch.GetMaterialTexture(materialIndex);
      // texture coordinates (if multipatch.HasTextures = true)
      if (hasTextures)
        int numPatchTexturePoints = multipatch.GetPatchTextureVertexCount(patchIndex);
        var coordinate2D = multipatch.GetPatchTextureCoordinate(patchIndex, 0);
        ICollection<Coordinate2D> textureCoordinates = new List<Coordinate2D>(numPatchTexturePoints);
        multipatch.GetPatchTextureCoordinates(patchIndex, ref textureCoordinates);
      // patch normals (if multipatch.HasNormals = true)
      if (hasNormals)
        //  number of normal coordinates = multipatch.GetPatchPointCount(patchIndex)
        Coordinate3D patchNormal = multipatch.GetPatchNormal(patchIndex, 0);
        ICollection<Coordinate3D> normalCoordinates = new List<Coordinate3D>(patchPointCount);
        multipatch.GetPatchNormals(patchIndex, ref normalCoordinates);
    Requirements
