ArcGIS.Core.SystemCore Namespace / IArcGISSignOn Interface / IsSignedOn Method
The uri of the portal to check for signon
    IsSignedOn Method (IArcGISSignOn)
    Check if the portal provided by the Uri is signed on. This method is for use in CoreHost applications only
    Syntax
    Function IsSignedOn( _
       ByVal portalUri As Uri _
    ) As Boolean
    bool IsSignedOn(
       Uri portalUri
    Parameters
    portalUri
    Return Value
    True if the portal at the specified portalUri is signed on
    Remarks
    For use in CoreHost applications only
    Requirements
