Inheritance Hierarchy
    ArcGIS.Core.SystemCore Namespace
    This namespace contains types that support various utility methods.
    Classes
     ClassDescription
    Class For use with CoreHost applications that need to authenticate with portal or arcgis online.
    Class Class to provide connectivity state methods..
    Class Configure the unit conversion parameters
    Class This is a singleton. Use to provide your unit format conversion needs.
    Class Thrown when a parameter is invalid.
    Class General system core exception; for example if a conversion combination is not supported.
    Interfaces
     InterfaceDescription
    Interface For use with CoreHost applications that need to authenticate with portal or arcgis online.
    Interface Unit conversion interface.
    Interface CoreHost applications implement an ISignOnHandler to receive callbacks from the system whenever authentication is required for a portal or arcgis online.
    Structures
     StructureDescription
    StructurePassed as the parameter to ISignOnHandler.GenerateCredentials
    Enumerations
     EnumerationDescription
    EnumerationSet of values indicating connection status. See Connectivity.GetInternetConnectionStatus.
    Enumeration Describes the different types of systemCore exceptions.
