ArcGIS.Core.SystemCore Namespace / IArcGISSignOn Interface / SignInWithCredentials Method
The uri of the portal to sign on to
The user name to use for credentails or null
The password to use for credentials or null
The referer to use with the access token
The returned access token
    SignInWithCredentials Method (IArcGISSignOn)
    Sign in to the portal provided by the Uri. This method is for use in CoreHost applications only
    Syntax
    bool SignInWithCredentials(
       Uri portalUri,
       string user,
       string password,
       out string referer,
       out string token
    Function SignInWithCredentials( _
       ByVal portalUri As Uri, _
       ByVal user As String, _
       ByVal password As String, _
       ByRef referer As String, _
       ByRef token As String _
    ) As Boolean
    Parameters
    portalUri
    user
    password
    referer
    token
    Remarks
    For use in CoreHost applications only.
    Requirements
