Modify(Table,Int64,Dictionary<Int32,Object>) Method
Modify a row, updating the attribute values. This method must be called on the MCT. Use QueuedTask.Run.
Syntax
Parameters
- table
- The table of the row to update.
- oid
- The oid of the row to update.
- attributes
- The attribute values to update (by field index).
Exceptions
Example
Edit Operation Modify single feature
// Modifies a single feature in the specified feature layer.
await QueuedTask.Run(() =>
var modifyFeature = new EditOperation() { Name = "Modify a feature" };
//use an inspector
var modifyInspector = new Inspector();
modifyInspector.Load(featureLayer, objectId);//base attributes on an existing feature
//change attributes for the new feature
modifyInspector["SHAPE"] = polygon;//Update the geometry
modifyInspector["NAME"] = "Updated name";//Update attribute(s)
modifyFeature.Modify(modifyInspector);
//update geometry and attributes using overload
var featureAttributes = new Dictionary<string, object>
["NAME"] = "Updated name"//Update attribute(s)
modifyFeature.Modify(featureLayer, objectId, polygon, featureAttributes);
//Execute to execute the operation
//Must be called within QueuedTask.Run
if (!modifyFeature.IsEmpty)
//Execute and ExecuteAsync will return true if the operation was successful and false if not
var result = modifyFeature.Execute();
//or use async flavor
//await modifyFeatures.ExecuteAsync();
Move feature to a specific coordinate
// Moves the first selected feature in the specified feature layer to the given coordinates.
await QueuedTask.Run<bool>(() =>
//Get all of the selected ObjectIDs from the layer.
var mySelection = featureLayer.GetSelection();
var selOid = mySelection.GetObjectIDs()?[0];
var xCoordinate = 0.0;
var yCoordinate = 0.0; // specify the target coordinates to move the geometry
var moveToPoint = new MapPointBuilderEx(xCoordinate, yCoordinate, 0.0, 0.0, featureLayer.GetSpatialReference());
var moveEditOperation = new EditOperation() { Name = "Move features" };
moveEditOperation.Modify(featureLayer, selOid ?? -1, moveToPoint.ToGeometry()); //Modify the feature to the new geometry
if (!moveEditOperation.IsEmpty)
var result = moveEditOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
return result; // return the operation result: true if successful, false if not
return false; // return false to indicate that the operation was not empty
Order edits sequentially
// Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation.
// perform an edit and then a split as one operation.
var newName = "Modified then Split";
var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() };
// create an edit operation and name.
var op = new EditOperation
Name = "modify followed by split", // set the ExecuteMode
ExecuteMode = ExecuteModeType.Sequential
using (var rowCursor = layer.Search(queryFilter))
while (rowCursor.MoveNext())
using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature;
op.Modify(feature, "NAME", newName);
op.Split(layer, objectId, splitLine);
if (!op.IsEmpty)
bool result = op.Execute();
// else
// The operation doesn't make any changes to the database so if executed it will fail
Read and Write blob fields with the attribute inspector
// get selected feature into inspector
var selectedFeatures = activeMap.GetSelection();
var insp = new Inspector();
insp.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First());
// read a blob field and save to a file
var msw = new MemoryStream();
msw = insp["BlobField"] as MemoryStream;
using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write))
msw.WriteTo(file);
// read file into memory stream
var msr = new MemoryStream();
using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read))
file.CopyTo(msr);
//put the memory stream in the blob field and save to feature
var op = new EditOperation() { Name = "Blob Inspector" };
insp["Blobfield"] = msr;
op.Modify(insp);
if (!op.IsEmpty)
var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
Write a compressed image to a raster field
//Open the raster dataset on disk and create a compressed raster value dataset object
var dataStore = new ArcGIS.Core.Data.FileSystemDatastore(new ArcGIS.Core.Data.FileSystemConnectionPath(new Uri(@"e:\temp"), ArcGIS.Core.Data.FileSystemDatastoreType.Raster));
using (var fileRasterDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Raster.RasterDataset>("Hydrant.jpg"))
var storageDef = new ArcGIS.Core.Data.Raster.RasterStorageDef();
storageDef.SetCompressionType(ArcGIS.Core.Data.Raster.RasterCompressionType.JPEG);
storageDef.SetCompressionQuality(90);
var rv = new ArcGIS.Core.Data.Raster.RasterValue();
rv.SetRasterDataset(fileRasterDataset);
rv.SetRasterStorageDef(storageDef);
var sel = MapView.Active.Map.GetSelection();
//insert a raster value object into the raster field
var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
insp.Load(sel.ToDictionary().Keys.First(), sel.ToDictionary().Values.First());
insp["Photo"] = rv;
var op = new EditOperation() { Name = "Raster Inspector" };
op.Modify(insp);
if (!op.IsEmpty)
Update Annotation Text via attribute.
var oid = 1;
// See "Change Annotation Text Graphic" for an alternative if TEXTSTRING is missing from the schema
// Note: QueuedTask is required to access the Inspector
// use the inspector methodology
insp.Load(annotationLayer, oid);
// make sure TextString attribute exists.
//It is not guaranteed to be in the schema
ArcGIS.Desktop.Editing.Attributes.Attribute att = insp.FirstOrDefault(a => a.FieldName == "TEXTSTRING");
if (att != null)
insp["TEXTSTRING"] = "Hello World";
//create and execute the edit operation
EditOperation op = new EditOperation();
op.Name = "Update annotation";
op.Modify(insp);
//OR using a Dictionary - again TEXTSTRING has to exist in the schema
//Dictionary<string, object> newAtts = new Dictionary<string, object>();
//newAtts.Add("TEXTSTRING", "hello world");
//op.Modify(annotationLayer, oid, newAtts);
op.Execute();
Edit the attributes of a FeatureSceneLayer
//must support editing!
if (!featSceneLayer.HasAssociatedFeatureService ||
!featSceneLayer.IsEditable)
return;
// Note: call within QueuedTask.Run()
var editOp = new EditOperation()
Name = "Edit FeatureSceneLayer Attributes",
SelectModifiedFeatures = true
//make an inspector
var inspector = new Inspector();
//get the attributes for the specified oid
inspector.Load(featSceneLayer, oid);
inspector["PermitNotes"] = "test";//modify
editOp.Modify(inspector);
editOp.Execute();//synchronous flavor
Requirements
