| Name | Description | |
![]() | EditOperation Constructor | Constructs a new EditOperation representing an edit to be performed against the Geodatabase. |
The following tables list the members exposed by EditOperation.
![]() | CancelMessage | Gets and sets the cancel message. |
![]() | EditOperationType | Gets and sets the transaction type for the EditOperation. |
![]() | ErrorMessage | Gets and sets the ErrorMessage. |
![]() | EventToken | Provides a way for calling code to identify a particular EditOperation within a subsequent EditEvent. Setting an EventToken in an EditOperation is optional - by default it is null. If set to a non-null object, the EditOperation is subsequently successful, and, an EditEvent is published, then the EventToken object set here, will be available from the corresponding ArcGIS.Desktop.Editing.Events.EditCompletedEventArgs.EventToken. |
![]() | ExecuteMode | Gets and sets the execute mode for the operation. Default value is ExecuteModeType.Default. |
![]() | IsCanceled | Gets a value indicating if the EditOperation has been Canceled. EditOperations are marked as Canceled when they have been Executed but canceled before completing and not performed. |
![]() | IsDone | Gets a value indicating if the EditOperation is Done. EditOperations are marked as Done when someone calls ExecuteAsync() on them (even before they are complete). |
![]() | IsEmpty | Gets a value indicating if the EditOperation is empty. |
![]() | IsSucceeded | Gets a value indicating if the EditOperation Succeeded. EditOperations are marked as Succeeded when ExecuteAsync() succeeds (the Task terminates with true). |
![]() | Name | Gets and sets the string reported to the application's undo stack for this EditOperation. |
![]() | ProgressMessage | Gets and sets the string to show while executing this operation. |
![]() | SelectModifiedFeatures | Gets and sets whether a new selection containing only the modified features will be created by the EditOperation. |
![]() | SelectNewFeatures | Gets and sets whether a new selection containing only the created features will be created by the EditOperation. |
![]() | ShowModalMessageAfterFailure | Gets and sets a value to show a modal dialog if the EditOperation fails. |
![]() | ShowProgressor | Gets and sets whether to show a progressor during an EditOperation. |
![]() | Abort | Mark the Edit Operation as aborted. |
![]() | AddAttachment | Overloaded. |
![]() | AssignFeaturesToRecord | Overloaded. |
![]() | AutoComplete | Overloaded. Create a new feature by auto-complete. |
![]() | BuildParcelsByExtent | Build parcel features within the given extent of the parcel layer. |
![]() | BuildParcelsByRecord | Build parcel features that are assigned to the specified record. |
![]() | Callback | Overloaded. Registers that the edit operation will callback into the given function in the context of an edit operation. |
![]() | CanCreateTraverse | Determines if the features can be created for the traverse using the specified template. |
![]() | ChangeParcelType | Overloaded. |
![]() | Clip | Overloaded. |
![]() | ConstructPolygons | Overloaded. |
![]() | Copy | Copies the specified rows from the source mapMember to the destination mapMember. |
![]() | CopyLineFeaturesToParcelType | Overloaded. |
![]() | CopyParcelLinesToParcelType | Overloaded. |
![]() | Create | Overloaded. Create a new feature in a layer or row in a table. |
![]() | CreateChainedOperation | Creates a follow-on operation which will be shared with this operation on the application's undo stack. |
![]() | CreateEx | Overloaded. |
![]() | CreateParcelSeedsByRecord | Overloaded. |
![]() | CreateTraverse | Creates features using the traverse courses and the specified feature template. This method must be called on the MCT. Use QueuedTask.Run. |
![]() | Delete | Overloaded. |
![]() | DeleteParcels | Delete parcel polygon features. |
![]() | Duplicate | Adds an edit operation that creates a duplicate of the specified feature with given geometry offsets. |
![]() | DuplicateParcels | Overloaded. |
![]() | Execute | Executes the Edit, modifying the database using the instructions given to the EditOperation. Returns true upon success and false upon failure. |
![]() | ExecuteAsync | Executes the Edit, modifying the database using the instructions given to the EditOperation. Returns true upon success and false upon failure. |
![]() | Explode | Overloaded. |
![]() | GetAwaiter | This method is intended for compiler use rather than for use in application code. The presence of this method allows an EditOperation to be 'await'-ed like a Task (the Task returned by calling ExecuteAsync()). |
![]() | Merge | Overloaded. Merge features. |
![]() | Modify | Overloaded. Modify the geometry and/or the attributes of features or rows. |
![]() | Move | Overloaded. Move a set of features by a vector. |
![]() | Planarize | Overloaded. |
![]() | ReassignFeaturesToRecord | Overloaded. |
![]() | ReconstructParcelsFromSeeds | Reconstruct all parcel seeds within the given extent of the parcel layer. |
![]() | RedoAsync | Attempts to Redo this EditOperation (only the most recently undone edit operation can be redone). |
![]() | RemoveAllAttachments | Overloaded. |
![]() | RemoveAttachment | Overloaded. |
![]() | Reshape | Overloaded. Reshape features with a geometry. |
![]() | RetireFeaturesToRecord | Overloaded. |
![]() | Rotate | Overloaded. |
![]() | Rubbersheet | Overloaded. |
![]() | Scale | Overloaded. |
![]() | SetOnComitted | Sets an action that will be called when this EditOperation is committed. |
![]() | SetOnComplete | Sets an action that will be called when this operation is done executing. |
![]() | SetOnRedone | Sets an action that will be called when this EditOperation is redone. |
![]() | SetOnUndone | Sets an action that will be called when this EditOperation is undone. |
![]() | SetParcelHistoryCurrent | Set the history of the selected parcel features to current. |
![]() | SetParcelHistoryRetired | Overloaded. |
![]() | ShrinkParcelsToSeeds | Shrink selected parcels to seeds. |
![]() | Split | Overloaded. |
![]() | TransferAttributes | Overloaded. |
![]() | TransferParcel | Overloaded. |
![]() | Transform | Overloaded. |
![]() | UndoAsync | Attempts to Undo this EditOperation (only the most recent edit operation can be undone). |
![]() | UpdateAttachment | Overloaded. |
