// Creates new features in a feature layer using the specified geometry, attributes, or editing template. await QueuedTask.Run(() => { var createFeatures = new EditOperation() { Name = "Create Features" }; //Create a feature with a polygon var token = createFeatures.Create(featureLayer, polygon); if (createFeatures.IsSucceeded) { // token.ObjectID will be populated with the objectID of the created feature after Execute has been successful } //Do a create features and set attributes var attributes = new Dictionary<string, object> { { "SHAPE", polygon }, { "NAME", "Corner Market" }, { "SIZE", 1200.5 }, { "DESCRIPTION", "Corner Market" } }; createFeatures.Create(featureLayer, attributes); //Create features using the current template //Must be within a MapTool createFeatures.Create(currentTemplate, polygon); //Execute to execute the operation //Must be called within QueuedTask.Run if (!createFeatures.IsEmpty) { //Execute will return true if the operation was successful and false if not. createFeatures.Execute(); //or use async flavor //await createFeatures.ExecuteAsync(); } });
