ArcGIS.Desktop.Editing Namespace / EditOperation Class / IsEmpty Property
Example
    IsEmpty Property (EditOperation)
    Gets a value indicating if the EditOperation is empty.
    Syntax
    Public ReadOnly Property IsEmpty As Boolean
    public bool IsEmpty {get;}
    Property Value
    true if the EditOperation has no methods set before executing.
    Remarks
    This is used internally before executing the operation to test if any methods have been set.
    Example
    Edit Operation - check for actions before Execute
    // Checks for pending actions in an edit operation before attempting to execute it.
    await QueuedTask.Run(() =>
      // Create an edit operation
      var op = new EditOperation() { Name = "My Edit Operation" };
      // Add some actions to the edit operation
      op.Modify(featureLayer, objectId, geometry);
      // EditOperation.Modify can unknowingly set an attribute to the already existing value
      // In this scenario the Modify action will detect that no changes are required and consequently the Execute operation will fail.
      // To avoid this, we can check if the edit operation is empty before executing it.
      if (!op.IsEmpty)
        // Execute the edit operation
        var result = op.Execute();
        Debug.WriteLine($"Edit operation executed successfully: {result}");
      else
        Debug.WriteLine("No actions to execute in the edit operation.");
    Requirements
