ArcGIS.Desktop.Editing Namespace / EditOperation Class / BuildParcelsByRecord Method
The parcel layer to build.
Record of features to build.
Layers that the editor listens to for database changes. This allows edit operations like SelectNewFeatures, SelectModifiedFeatures to act on feature changes.
Example
    Build parcel features that are assigned to the specified record.
    Syntax
    Public Function BuildParcelsByRecord( _
       ByVal parcelLayer As ParcelLayer, _
       ByVal recordGuid As Guid, _
       Optional ByVal layers As IEnumerable(Of MapMember) _
    ) As ParcelEditToken
    Parameters
    parcelLayer
    recordGuid
    layers
    Exceptions
    ExceptionDescription
    ParcelLayer and recordGuid cannot be null.
    Insufficient license. This method requires a standard license.
    Example
    Build parcels
    try
      var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
      if (myParcelFabricLayer == null)
        return "Parcel layer not found in map.";
      var theActiveRecord = myParcelFabricLayer.GetActiveRecord();
      var guid = theActiveRecord.Guid;
      var editOper = new EditOperation()
        Name = "Build Parcels",
        ProgressMessage = "Build Parcels...",
        ShowModalMessageAfterFailure = true,
        SelectNewFeatures = true,
        SelectModifiedFeatures = true
      editOper.BuildParcelsByRecord(myParcelFabricLayer, guid);
      if (!editOper.Execute())
        return editOper.ErrorMessage;
    catch (Exception ex)
      return ex.Message;
    return "";
    Requirements
