Public NotInheritable Class ParcelLayer Inherits CompositeLayer Implements ArcGIS.Desktop.Core.IMetadataInfo, ILayerContainer, IMetadataSource, System.ComponentModel.INotifyPropertyChanged
public sealed class ParcelLayer : CompositeLayer, ArcGIS.Desktop.Core.IMetadataInfo, ILayerContainer, IMetadataSource, System.ComponentModel.INotifyPropertyChanged
string path = @"C:\MyTestData\MyFileGeodatabase.gdb\MyFeatureDS\MyFabric"; await QueuedTask.Run(() => { var lyrCreateParams = new ParcelLayerCreationParams(new Uri(path)); try { var parcelLayer = LayerFactory.Instance.CreateLayer<ParcelLayer>( lyrCreateParams, MapView.Active.Map); } catch (Exception ex) { MessageBox.Show(ex.Message, "Add Parcel Fabric Layer"); } });
string errorMessage = await QueuedTask.Run(() =>
try
var myParcelFabricLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<ParcelLayer>().FirstOrDefault();
//if there is no fabric in the map then bail
if (myParcelFabricLayer == null)
return "There is no fabric in the map.";
var theActiveRecord = myParcelFabricLayer.GetActiveRecord();
if (theActiveRecord == null)
return "There is no Active Record. Please set the active record and try again.";
return ex.Message;
return "";
if (!string.IsNullOrEmpty(errorMessage))
MessageBox.Show(errorMessage, "Get Active Record.");
string errorMessage = await QueuedTask.Run(async () =>
try
string sExistingRecord = "MyRecordName";
bool bSuccess = await myParcelFabricLayer.SetActiveRecordAsync(sExistingRecord);
if (!bSuccess)
return "No record called " + sExistingRecord + " was found.";
return ex.Message;
return "";
MessageBox.Show(errorMessage, "Set Active Record.");
System.Object
ArcGIS.Desktop.Framework.Contracts.PropertyChangedBase
ArcGIS.Desktop.Mapping.MapMember
ArcGIS.Desktop.Mapping.Layer
ArcGIS.Desktop.Mapping.CompositeLayer
ArcGIS.Desktop.Mapping.ParcelLayer
