Parameters
- callback
- The action to take when this operation is redone.
// Demonstrates how to use the <see cref="ArcGIS.Desktop.Editing.EditOperation"/> methods <see await QueuedTask.Run(() => { // SetOnUndone, SetOnRedone and SetOnComitted can be used to manage // external actions(such as writing to a log table) that are associated with // each edit operation. //get selected feature and update attribute var selectedFeatures = MapView.Active.Map.GetSelection(); var testInspector = new Inspector(); testInspector.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First()); testInspector["Name"] = "test"; //create and execute the edit operation var updateTestField = new EditOperation() { Name = "Update test field" }; updateTestField.Modify(testInspector); //actions for SetOn... updateTestField.SetOnUndone(() => { //Sets an action that will be called when this operation is undone. Debug.WriteLine("Operation is undone"); }); updateTestField.SetOnRedone(() => { //Sets an action that will be called when this edit operation is redone. Debug.WriteLine("Operation is redone"); }); updateTestField.SetOnComitted(b => { // Sets an action that will be called when this edit operation is committed. Debug.WriteLine("Operation is committed"); }); if (!updateTestField.IsEmpty) { var result = updateTestField.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
