// Demonstrates how to use the <see cref="ArcGIS.Desktop.Editing.EditOperation"/> methods <see
await QueuedTask.Run(() =>
// SetOnUndone, SetOnRedone and SetOnComitted can be used to manage
// external actions(such as writing to a log table) that are associated with
// each edit operation.
//get selected feature and update attribute
var selectedFeatures = MapView.Active.Map.GetSelection();
var testInspector = new Inspector();
testInspector.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First());
testInspector["Name"] = "test";
//create and execute the edit operation
var updateTestField = new EditOperation() { Name = "Update test field" };
updateTestField.Modify(testInspector);
//actions for SetOn...
updateTestField.SetOnUndone(() =>
//Sets an action that will be called when this operation is undone.
Debug.WriteLine("Operation is undone");
updateTestField.SetOnRedone(() =>
//Sets an action that will be called when this edit operation is redone.
Debug.WriteLine("Operation is redone");
updateTestField.SetOnComitted(b =>
// Sets an action that will be called when this edit operation is committed.
Debug.WriteLine("Operation is committed");
if (!updateTestField.IsEmpty)
var result = updateTestField.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
