Parameters
- table
- The table of the row to update.
- oid
- The oid of the row to update.
- fieldName
- The field name to update.
- value
- The new value.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Modifies a single feature in the specified feature layer. await QueuedTask.Run(() => { var modifyFeature = new EditOperation() { Name = "Modify a feature" }; //use an inspector var modifyInspector = new Inspector(); modifyInspector.Load(featureLayer, objectId);//base attributes on an existing feature //change attributes for the new feature modifyInspector["SHAPE"] = polygon;//Update the geometry modifyInspector["NAME"] = "Updated name";//Update attribute(s) modifyFeature.Modify(modifyInspector); //update geometry and attributes using overload var featureAttributes = new Dictionary<string, object> { ["NAME"] = "Updated name"//Update attribute(s) }; modifyFeature.Modify(featureLayer, objectId, polygon, featureAttributes); //Execute to execute the operation //Must be called within QueuedTask.Run if (!modifyFeature.IsEmpty) { //Execute and ExecuteAsync will return true if the operation was successful and false if not var result = modifyFeature.Execute(); //or use async flavor //await modifyFeatures.ExecuteAsync(); } });
// Moves the first selected feature in the specified feature layer to the given coordinates. await QueuedTask.Run<bool>(() => { //Get all of the selected ObjectIDs from the layer. var mySelection = featureLayer.GetSelection(); var selOid = mySelection.GetObjectIDs()?[0]; var xCoordinate = 0.0; var yCoordinate = 0.0; // specify the target coordinates to move the geometry var moveToPoint = new MapPointBuilderEx(xCoordinate, yCoordinate, 0.0, 0.0, featureLayer.GetSpatialReference()); var moveEditOperation = new EditOperation() { Name = "Move features" }; moveEditOperation.Modify(featureLayer, selOid ?? -1, moveToPoint.ToGeometry()); //Modify the feature to the new geometry if (!moveEditOperation.IsEmpty) { var result = moveEditOperation.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not return result; // return the operation result: true if successful, false if not } return false; // return false to indicate that the operation was not empty });
// Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation. // perform an edit and then a split as one operation. await QueuedTask.Run(() => { var newName = "Modified then Split"; var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() }; // create an edit operation and name. var op = new EditOperation { Name = "modify followed by split", // set the ExecuteMode ExecuteMode = ExecuteModeType.Sequential }; using (var rowCursor = layer.Search(queryFilter)) { while (rowCursor.MoveNext()) { using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature; op.Modify(feature, "NAME", newName); } } op.Split(layer, objectId, splitLine); if (!op.IsEmpty) { bool result = op.Execute(); } // else // The operation doesn't make any changes to the database so if executed it will fail });
await QueuedTask.Run(() => { // get selected feature into inspector var selectedFeatures = activeMap.GetSelection(); var insp = new Inspector(); insp.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First()); // read a blob field and save to a file var msw = new MemoryStream(); msw = insp["BlobField"] as MemoryStream; using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write)) { msw.WriteTo(file); } // read file into memory stream var msr = new MemoryStream(); using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read)) { file.CopyTo(msr); } //put the memory stream in the blob field and save to feature var op = new EditOperation() { Name = "Blob Inspector" }; insp["Blobfield"] = msr; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } });
await QueuedTask.Run(() => { //Open the raster dataset on disk and create a compressed raster value dataset object var dataStore = new ArcGIS.Core.Data.FileSystemDatastore(new ArcGIS.Core.Data.FileSystemConnectionPath(new Uri(@"e:\temp"), ArcGIS.Core.Data.FileSystemDatastoreType.Raster)); using (var fileRasterDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Raster.RasterDataset>("Hydrant.jpg")) { var storageDef = new ArcGIS.Core.Data.Raster.RasterStorageDef(); storageDef.SetCompressionType(ArcGIS.Core.Data.Raster.RasterCompressionType.JPEG); storageDef.SetCompressionQuality(90); var rv = new ArcGIS.Core.Data.Raster.RasterValue(); rv.SetRasterDataset(fileRasterDataset); rv.SetRasterStorageDef(storageDef); var sel = MapView.Active.Map.GetSelection(); //insert a raster value object into the raster field var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector(); insp.Load(sel.ToDictionary().Keys.First(), sel.ToDictionary().Values.First()); insp["Photo"] = rv; var op = new EditOperation() { Name = "Raster Inspector" }; op.Modify(insp); if (!op.IsEmpty) { var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not } } });
var oid = 1;
// See "Change Annotation Text Graphic" for an alternative if TEXTSTRING is missing from the schema
// Note: QueuedTask is required to access the Inspector
// use the inspector methodology
insp.Load(annotationLayer, oid);
// make sure TextString attribute exists.
//It is not guaranteed to be in the schema
ArcGIS.Desktop.Editing.Attributes.Attribute att = insp.FirstOrDefault(a => a.FieldName == "TEXTSTRING");
if (att != null)
insp["TEXTSTRING"] = "Hello World";
//create and execute the edit operation
EditOperation op = new EditOperation();
op.Name = "Update annotation";
op.Modify(insp);
//OR using a Dictionary - again TEXTSTRING has to exist in the schema
//Dictionary<string, object> newAtts = new Dictionary<string, object>();
//newAtts.Add("TEXTSTRING", "hello world");
//op.Modify(annotationLayer, oid, newAtts);
op.Execute();
//must support editing!
if (!featSceneLayer.HasAssociatedFeatureService ||
!featSceneLayer.IsEditable)
return;
// Note: call within QueuedTask.Run()
var editOp = new EditOperation()
Name = "Edit FeatureSceneLayer Attributes",
SelectModifiedFeatures = true
//make an inspector
var inspector = new Inspector();
//get the attributes for the specified oid
inspector.Load(featSceneLayer, oid);
inspector["PermitNotes"] = "test";//modify
editOp.Modify(inspector);
editOp.Execute();//synchronous flavor
