ArcGIS.Desktop.Editing Namespace / EditOperation Class / Modify Method / Modify(Table,Int64,Int32,Object) Method
The table of the row to update.
The FeatureID of the row to update.
The field index to update
The new value.
Example
    Modify a row, updating the attribute values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Modify(
       Table table,
       long oid,
       int fieldIndex,
       object value
    Public Overloads Sub Modify( _
       ByVal table As Table, _
       ByVal oid As Long, _
       ByVal fieldIndex As Integer, _
       ByVal value As Object _
    Parameters
    table
    oid
    fieldIndex
    value
    The new value.
    Exceptions
    ExceptionDescription
    Example
    Order edits sequentially
    // Modifies the "NAME" attribute of a specified feature and then splits the feature using the provided polyline, all within a single sequential edit operation.
    // perform an edit and then a split as one operation.
    await QueuedTask.Run(() =>
       var newName = "Modified then Split";
       var queryFilter = new QueryFilter() { WhereClause = "OBJECTID = " + objectId.ToString() };
       // create an edit operation and name.
       var op = new EditOperation
         Name = "modify followed by split",         // set the ExecuteMode
         ExecuteMode = ExecuteModeType.Sequential
       using (var rowCursor = layer.Search(queryFilter))
         while (rowCursor.MoveNext())
           using var feature = rowCursor.Current as ArcGIS.Core.Data.Feature;
           op.Modify(feature, "NAME", newName);
       op.Split(layer, objectId, splitLine);
       if (!op.IsEmpty)
         bool result = op.Execute();
       // else
       //  The operation doesn't make any changes to the database so if executed it will fail
    Read and Write blob fields with the attribute inspector
      // get selected feature into inspector
      var selectedFeatures = activeMap.GetSelection();
      var insp = new Inspector();
      insp.Load(selectedFeatures.ToDictionary().Keys.First(), selectedFeatures.ToDictionary().Values.First());
      // read a blob field and save to a file
      var msw = new MemoryStream();
      msw = insp["BlobField"] as MemoryStream;
      using (FileStream file = new(@"d:\temp\blob.jpg", FileMode.Create, FileAccess.Write))
        msw.WriteTo(file);
      // read file into memory stream
      var msr = new MemoryStream();
      using (FileStream file = new(@"d:\images\Hydrant.jpg", FileMode.Open, FileAccess.Read))
        file.CopyTo(msr);
      //put the memory stream in the blob field and save to feature
      var op = new EditOperation() { Name = "Blob Inspector" };
      insp["Blobfield"] = msr;
      op.Modify(insp);
      if (!op.IsEmpty)
        var result = op.Execute(); //Execute and ExecuteAsync will return true if the operation was successful and false if not
    Write a compressed image to a raster field
    var compressedRasterMapView = MapView.Active;
    if (compressedRasterMapView == null)
      return;
      //Open the raster dataset on disk and create a compressed raster value dataset object
      var dataStore = new ArcGIS.Core.Data.FileSystemDatastore(new ArcGIS.Core.Data.FileSystemConnectionPath(new Uri(@"e:\temp"), ArcGIS.Core.Data.FileSystemDatastoreType.Raster));
      using (var fileRasterDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Raster.RasterDataset>("Hydrant.jpg"))
        var storageDef = new ArcGIS.Core.Data.Raster.RasterStorageDef();
        storageDef.SetCompressionType(ArcGIS.Core.Data.Raster.RasterCompressionType.JPEG);
        storageDef.SetCompressionQuality(90);
        var rv = new ArcGIS.Core.Data.Raster.RasterValue();
        rv.SetRasterDataset(fileRasterDataset);
        rv.SetRasterStorageDef(storageDef);
        var sel = compressedRasterMapView.Map.GetSelection();
        //insert a raster value object into the raster field
        var insp = new ArcGIS.Desktop.Editing.Attributes.Inspector();
        insp.Load(sel.ToDictionary().Keys.First(), sel.ToDictionary().Values.First());
        insp["Photo"] = rv;
        var op = new EditOperation() { Name = "Raster Inspector" };
        op.Modify(insp);
        if (!op.IsEmpty)
    Requirements
