ArcGIS.Desktop.Editing Namespace / EditOperation Class / TransferAttributes Method / TransferAttributes(MapMember,Int64,MapMember,Int64) Method
The source layer (or standalone table)
The source feature (or row)'s OID
The target layer (or standalone table)
The target feature (or row)'s OID
Example
    Transfer attributes between two features (or rows) using the stored field mapping.
    Syntax
    Public Overloads Sub TransferAttributes( _
       ByVal source As MapMember, _
       ByVal sourceOID As Long, _
       ByVal target As MapMember, _
       ByVal targetOID As Long _
    public void TransferAttributes(
       MapMember source,
       long sourceOID,
       MapMember target,
       long targetOID
    Parameters
    source
    sourceOID
    target
    targetOID
    Example
    Edit Operation: Transfer Attributes
    // Transfers attributes from a source feature to a target feature between specified layers.
    await QueuedTask.Run(() =>
        var targetOID = 12345; // object ID of the target feature in the destination layer
        var transferAttributes = new EditOperation() { Name = "Transfer Attributes" };
        // transfer attributes using the stored field mapping
        transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID);
        //Execute to execute the operation
        //Must be called within QueuedTask.Run
        if (!transferAttributes.IsEmpty)
          //Execute and ExecuteAsync will return true if the operation was successful and false if not
          var result = transferAttributes.Execute();
          //or use async flavor
          //await transferAttributes.ExecuteAsync();
        // transfer attributes using an auto-match on the attributes
        transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, "");
    // Transfers attributes from a source feature to a target feature in a specified destination layer.
       // transfer attributes using a specified set of field mappings
       //  dictionary key is the field name in the destination layer, dictionary value is the field name in the source layer
       Dictionary<string, string> fldMapping = new()         {
        { "NAME", "SURNAME" },
        { "ADDRESS", "ADDRESS" }
       transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, fldMapping);
        // transfer attributes using a custom field mapping expression
        string expression = "return {\r\n  " +
            "\"ADDRESS\" : $sourceFeature['ADDRESS'],\r\n  " +
            "\"IMAGE\" : $sourceFeature['IMAGE'],\r\n  + " +
            "\"PRECINCT\" : $sourceFeature['PRECINCT'],\r\n  " +
            "\"WEBSITE\" : $sourceFeature['WEBSITE'],\r\n  " +
            "\"ZIP\" : $sourceFeature['ZIP']\r\n " +
        transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, expression);
    Requirements
