// Transfers attributes from a source feature to a target feature between specified layers.
await QueuedTask.Run(() =>
var targetOID = 12345; // object ID of the target feature in the destination layer
var transferAttributes = new EditOperation() { Name = "Transfer Attributes" };
// transfer attributes using the stored field mapping
transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID);
//Execute to execute the operation
//Must be called within QueuedTask.Run
if (!transferAttributes.IsEmpty)
//Execute and ExecuteAsync will return true if the operation was successful and false if not
var result = transferAttributes.Execute();
//or use async flavor
//await transferAttributes.ExecuteAsync();
// transfer attributes using an auto-match on the attributes
transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, "");
// Transfers attributes from a source feature to a target feature in a specified destination layer.
// transfer attributes using a specified set of field mappings
// dictionary key is the field name in the destination layer, dictionary value is the field name in the source layer
Dictionary<string, string> fldMapping = new() {
{ "NAME", "SURNAME" },
{ "ADDRESS", "ADDRESS" }
transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, fldMapping);
// transfer attributes using a custom field mapping expression
string expression = "return {\r\n " +
"\"ADDRESS\" : $sourceFeature['ADDRESS'],\r\n " +
"\"IMAGE\" : $sourceFeature['IMAGE'],\r\n + " +
"\"PRECINCT\" : $sourceFeature['PRECINCT'],\r\n " +
"\"WEBSITE\" : $sourceFeature['WEBSITE'],\r\n " +
"\"ZIP\" : $sourceFeature['ZIP']\r\n " +
transferAttributes.TransferAttributes(featureLayer, objectId, destinationLayer, targetOID, expression);
