ArcGIS.Desktop.Mapping Namespace / MappingExtensions Class / AddComponentTemplate Method
The group template the component template is to be added to.
The layer for the component part.
The name of the template used as the component part.
The builder method for the component part.
Options for the component part.
    Adds a component part to the group template. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    groupTemplate
    layer
    templateName
    builderMethod
    options
    Return Value
    The updated group template object.
    Exceptions
    ExceptionDescription
    The layer must exist and the template name must exist on the layer.
    This method must be called on the Main CIM Thread. Use QueuedTask.Run.
    Requirements
