ArcGIS.Desktop.Reports Namespace / Report Class / SetPage Method
The new page for the report.
Example
    SetPage Method (Report)
    Sets the page of the report. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub SetPage( _
       ByVal page As CIMPage _
    public void SetPage(
       CIMPage page
    Parameters
    page
    Exceptions
    ExceptionDescription
    Example
    Create a new layout using a modified CIM and open it
      //Create a new layout using a modified CIM and open it.
      //The CIM exposes additional members that may not be
      //available through the managed API.
      //In this example, optional guides are added.
      //Create a new CIMLayout on the worker thread
      //Note: Needs QueuedTask to run
      //Set up a CIM page
      CIMPage newPage = new CIMPage
        //required parameters
        Width = 8.5,
        Height = 11,
        Units = LinearUnit.Inches,
        //optional rulers
        ShowRulers = true,
        SmallestRulerDivision = 0.5,
        //optional guides
        ShowGuides = true
      CIMGuide guide1 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Vertical
      CIMGuide guide2 = new CIMGuide
        Position = 6.5,
      CIMGuide guide3 = new CIMGuide
        Position = 1,
        Orientation = Orientation.Horizontal
      CIMGuide guide4 = new CIMGuide
        Position = 10,
      List<CIMGuide> guideList = new List<CIMGuide>
        guide1,
        guide2,
        guide3,
        guide4
      newPage.Guides = guideList.ToArray();
      //Construct the new layout using the customized cim definitions
      var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
      layout_local.SetName("New 8.5x11 Layout");
      //Open new layout on the GUI thread
      await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
    Change the layout page size
      //Change the layout page size.
      //Reference the layout project item
      LayoutProjectItem lytItem = Project.Current.GetItems<LayoutProjectItem>()
                             .FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
      if (layoutItem != null)
        //Get the layout
        Layout lyt = lytItem.GetLayout();
        if (lyt != null)
          //Change properties
          CIMPage page = lyt.GetPage();
          page.Width = 8.5;
          page.Height = 11;
          //Apply the changes to the layout
          lyt.SetPage(page);
    Modify the report Page
      //Note: Call within QueuedTask.Run()
      var cimReportPage = new CIMPage
        Height = 12,
        StretchElements = false,
        Width = 6.5,
        ShowRulers = true,
        ShowGuides = true,
        Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
      report.SetPage(cimReportPage);
      //Change only the report's page height
      report.SetPageHeight(12);
    Requirements
