| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Note: call within QueuedTask.Run()
//Note: Use HasFilter to check if a given filter id exists in the layer
if (bsl.HasFilter(filter.ID))
bsl.SetActiveFilter(filter.ID);
var activeFilter = bsl.GetActiveFilter();
//Clear the active filter
bsl.ClearActiveFilter();
