ArcGIS.Desktop.Mapping Namespace / BuildingSceneLayer Class / HasFilter Method
The filter id to check
Example
    HasFilter Method
    Determines whether a filter exists with the given filter ID.
    Syntax
    Public Function HasFilter( _
       ByVal filterID As String _
    ) As Boolean
    public bool HasFilter(
       string filterID
    Parameters
    filterID
    Return Value
    Example
    Set and Clear Active Filter for BuildingSceneLayer
      // Note: call within QueuedTask.Run()
        //Note: Use HasFilter to check if a given filter id exists in the layer
        if (bsl.HasFilter(filter.ID))
          bsl.SetActiveFilter(filter.ID);
        var activeFilter = bsl.GetActiveFilter();
        //Clear the active filter
        bsl.ClearActiveFilter();
    Remove BuildingSceneLayer Filter
          bsl.RemoveFilter(filter.ID);
        //Or remove all filters
        bsl.RemoveAllFilters();
    Requirements
