ArcGIS.Desktop.Mapping Namespace / BuildingSceneLayer Class / RemoveAllFilters Method
Example
    Removes all the filters. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Sub RemoveAllFilters()
    public void RemoveAllFilters()
    Exceptions
    ExceptionDescription
    Remarks
    The active filter is also cleared
    Example
    Remove BuildingSceneLayer Filter
      // Note: call within QueuedTask.Run()
        //Note: Use HasFilter to check if a given filter id exists in the layer
        if (bsl.HasFilter(filter.ID))
          bsl.RemoveFilter(filter.ID);
        //Or remove all filters
        bsl.RemoveAllFilters();
    Requirements
