public RendererDefinition RendererDefinition {get; set;}
Public Property RendererDefinition As RendererDefinition
var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
Name = "World Cities",
IsVisible = false,
MinimumScale = 1000000,
MaximumScale = 5000,
DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var featureLayerWithParams = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map));
//Define a simple renderer to draw the Point US Cities feature class.
var simpleRender = new SimpleRendererDefinition
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 4.0, SimpleMarkerStyle.Circle).MakeSymbolReference()
//The catalog path of the feature layer to add to the map
var featureClassUri = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
//Define the Feature Layer's parameters.
var layerParams = new FeatureLayerCreationParams(featureClassUri)
//Set visibility
IsVisible = true,
//Set Renderer
RendererDefinition = simpleRender,
//Create the layer with the feature layer parameters and add it to the active map
var createdFCWithRenderer = await QueuedTask.Run(() =>
LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, map));
if (map == null)
return;
//Get an existing Layer. This layer has a symbol you want to use in a new layer.
var lyr = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
.Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
//This is the renderer to use in the new Layer
var renderer = lyr.GetRenderer() as CIMSimpleRenderer;
//Set the DataConnection for the new layer
Geodatabase geodatabase = new Geodatabase(
new FileGeodatabaseConnectionPath(new Uri(@"E:\Data\Admin\AdminData.gdb")));
FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("Cities");
var dataConnection = featureClass.GetDataConnection();
//Create the definition for the new feature layer
var featureLayerParams = new FeatureLayerCreationParams(dataConnection)
RendererDefinition = new SimpleRendererDefinition(renderer.Symbol),
IsVisible = true,
//create the new layer
featureLayerParams, map);
var featureLayerCreationParams = new FeatureLayerCreationParams(new Uri(@"c:\data\countydata.gdb\counties"))
Name = "Population Density (sq mi) Year 2010",
RendererDefinition = new GraduatedColorsRendererDefinition("POP10_SQMI")
await QueuedTask.Run(() => LayerFactory.Instance.CreateLayer<FeatureLayer>(
featureLayerCreationParams, map));
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/LABus/StreamServer";
var uri = new Uri(url, UriKind.Absolute);
var createParams = new FeatureLayerCreationParams(uri)
ColorFactory.Instance.BlueRGB,
12,
SimpleMarkerStyle.Pushpin).MakeSymbolReference()
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(
createParams, map);
