ArcGIS.Desktop.Mapping Namespace / FilterBlockDefinition Class / FilterBlockDefinition Constructor / FilterBlockDefinition Constructor(String,Object3DRenderingMode,Dictionary<String,List<String>>)
The title
The mode (solid "None" or wireframe)
The values that will be included in the filter
    Creates a FilterBlockDefinition.
    Syntax
    Parameters
    title
    The title
    filterBlockMode
    selectedValues
    Remarks
    The filter block definition class allows you to define parameters to create a building scene layer filter block. Once you define a filter block, you can create or set it on a FilterDefinition to create and assign a filter to a building scene layer.
    Requirements
