Public Property FilterBlockDefinitions As List(Of FilterBlockDefinition)
public List<FilterBlockDefinition> FilterBlockDefinitions {get; set;}
// Note: call within QueuedTask.Run()
var filter1 = bsl.CreateDefaultFilter();
var values = filter1.FilterBlockDefinitions[0].SelectedValues;
//values will be a single value for the type
//"CreatedPhase", value "New Construction"
//There will be at least one filter after "CreateDefaultFilter()" call
var filtersCount = bsl.GetFilters().Count;
//Note: wire_frame_filters can be null in this example
var wire_frame_filters = bsl.GetFilters().Where(
f => f.FilterBlockDefinitions.Any(
fb => fb.FilterBlockMode == Object3DRenderingMode.Wireframe));
//substitute Object3DRenderingMode.None to get blocks with a solid mode (default)
//and...
//fb.FilterBlockMode == Object3DRenderingMode.Wireframe &&
//fb.FilterBlockMode == Object3DRenderingMode.None
//for blocks with both
//refer to "Query Building Scene Layer for available Types and Values
var dict = bsl.GetAvailableFieldsAndValues();
var categories = dict.SingleOrDefault(kvp => kvp.Key == "Category").Value;
//get a list of existing floors or "levels"
var floors = dict.SingleOrDefault(kvp => kvp.Key == "BldgLevel").Value;
//Make a new filter definition
var fd = new FilterDefinition()
Name = "Floor and Category Filter",
Description = "Example filter",
//Set up the values for the filter
var filtervals = new Dictionary<string, List<string>>();
filtervals.Add("BldgLevel", new List<string>() { floors[0] });
var category_vals = categories.Where(v => v == "Walls" || v == "Stairs").ToList() ?? new List<string>();
if (category_vals.Count() > 0)
filtervals.Add("Category", category_vals);
//Create a solid block (other option is "Wireframe")
var fdef = new FilterBlockDefinition()
FilterBlockMode = Object3DRenderingMode.None,
Title = "Solid Filter",
SelectedValues = filtervals//Floor and Category
//Apply the block
fd.FilterBlockDefinitions = new List<FilterBlockDefinition>() { fdef };
//Add the filter definition to the layer
bsl.UpdateFilter(fd);
//Set it active. The ID is auto-generated
bsl.SetActiveFilter(fd.ID);
var filterBlock = new FilterBlockDefinition();
filterBlock.FilterBlockMode = Object3DRenderingMode.Wireframe;
var selectedValues = new Dictionary<string, List<string>>();
//We assume QueryAvailableFieldsAndValues() contains "Walls" and "Doors"
//For 'Category'
selectedValues["Category"] = new List<string>() { "Walls", "Doors" };
filterBlock.SelectedValues = selectedValues;
//Overwrite
filter.FilterBlockDefinitions = new List<FilterBlockDefinition>() { filterBlock };
bsl.UpdateFilter(filter);
