ArcGIS.Desktop.Mapping Namespace / LayerDocument Class / LayerDocument Constructor
    Overload List
    OverloadDescription
    Creates a LayerDocument instance using a ArcGIS.Core.CIM.CIMLayerDocument.
    Creates a LayerDocument instance from a Layer File (.lyrx). This constructor must be called on the MCT. Use QueuedTask.Run.
    Creates a LayerDocument instance from a MapMember object. This constructor must be called on the MCT. Use QueuedTask.Run.
    Creates a LayerDocument instance from a set of MapMember objects. This constructor must be called on the MCT. Use QueuedTask.Run.
    Requirements
