Return Value
A json encoded string.
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
await QueuedTask.Run(() =>
var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
//modifying its renderer symbol to red
var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
//optionally save the updates out as a file
lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
//get a json representation of the layer document and you want store away...
var aJSONString = lyrDocFromLyrxFile.AsJson();
//... and load it back when needed
lyrDocFromLyrxFile.Load(aJSONString);
//create a layer and add it to a map
var lcp = new LayerCreationParams(cimLyrDoc);
var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
