ArcGIS.Desktop.Mapping Namespace / LayerDocument Class / Save Method
A string represents a file path.
Example
    Save Method
    Save as a Layer File (.lyrx) This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void Save(
       string layerXFilePath
    Public Sub Save( _
       ByVal layerXFilePath As String _
    Parameters
    layerXFilePath
    Exceptions
    ExceptionDescription
    Example
    Create layer from a lyrx file
      await QueuedTask.Run(() =>
        var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
        var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
      //modifying its renderer symbol to red
      var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
      cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
      //optionally save the updates out as a file
      lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
      //get a json representation of the layer document and you want store away...
      var aJSONString = lyrDocFromLyrxFile.AsJson();
      //... and load it back when needed
      lyrDocFromLyrxFile.Load(aJSONString);
      //create a layer and add it to a map
        var lcp = new LayerCreationParams(cimLyrDoc);
        var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
    Create a Lyrx file
      LayerDocument layerDocument = new LayerDocument(layer);
      await QueuedTask.Run(() => layerDocument.Save(@"c:\Data\MyLayerDocument.lyrx"));
    Create a Lyrx file from mulltiple mapMembers
      // get the layers selected in the TOC
      var selectedLayers = MapView.Active.GetSelectedLayers();
      // get the standalonetables elected in the TOC
      var selectedTables = MapView.Active.GetSelectedStandaloneTables();
      var selectedMMs = new List<MapMember>(selectedLayers);
      selectedMMs.AddRange(selectedTables);
      // create the LayerDocument
      LayerDocument layerDocument = new LayerDocument(selectedMMs);
    Requirements
