ArcGIS.Desktop.Mapping Namespace / Map Class / ImportBookmarks Method
The path to the file
    Import bookmarks from ArcMap, ArcGlobe, and ArcScene bookmark files (*.dat) or ArcGIS Pro bookmark files (*.bmkx). This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    filePath
    Return Value
    The collection of bookmarks for the map.
    Exceptions
    ExceptionDescription
    Current project is null.
    Active map view is null.
    Invalid map path.
    Not supported file type.
    path is a zero-length string, contains only white space, or contains one or more invalid characters as defined by InvalidPathChars.
    path is null.
    The specified path, file name, or both exceed the system-defined maximum length.
    The specified path is invalid, (for example, it is on an unmapped drive).
    path specified a directory or the caller does not have the required permission.
    The file specified in path was not found.
    path is in an invalid format.
    An I/O error occurred while opening the file.
    General import failure.
    Requirements
