ArcGIS.Desktop.Mapping Namespace / PointCloudFilterDefinition Class
Members Example
    Represents a definition for a point cloud filter.
    Object Model
    PointCloudFilterDefinition ClassPointCloudFilterDefinition Class
    Syntax
    Public NotInheritable Class PointCloudFilterDefinition
    public sealed class PointCloudFilterDefinition
    Remarks
    The point cloud filter definition class allows you to define parameters to create a point cloud filter.
    Example
    Set a Filter for PointCloudSceneLayer
      // Note: call within QueuedTask.Run()
        //Retrieve the available classification codes
        var dict = pointCloudSceneLayer.GetAvailableClassCodesAndLabels();
        //Filter out low noise and unclassified (7 and 1 respectively)
        //consult https://pro.arcgis.com/en/pro-app/help/data/las-dataset/storing-lidar-data.htm
        var filterDef = new PointCloudFilterDefinition()
          ClassCodes = dict.Keys.Where(c => c != 7 && c != 1).ToList(),
          ReturnValues = new List<PointCloudReturnType> {
                            PointCloudReturnType.FirstOfMany }
        //apply the filter
        pointCloudSceneLayer.SetFilters(filterDef.ToCIM());
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Mapping.PointCloudFilterDefinition
    Requirements
