Public Sub SetFilters( _ ByVal filters As IEnumerable(Of CIMPointCloudFilter) _ )
public void SetFilters( IEnumerable<CIMPointCloudFilter> filters )
Parameters
- filters
- The enumeration of filters to set
| Exception | Description |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Note: call within QueuedTask.Run()
//Retrieve the available classification codes
var dict = pointCloudSceneLayer.GetAvailableClassCodesAndLabels();
//Filter out low noise and unclassified (7 and 1 respectively)
//consult https://pro.arcgis.com/en/pro-app/help/data/las-dataset/storing-lidar-data.htm
var filterDef = new PointCloudFilterDefinition()
ClassCodes = dict.Keys.Where(c => c != 7 && c != 1).ToList(),
ReturnValues = new List<PointCloudReturnType> {
PointCloudReturnType.FirstOfMany }
//apply the filter
pointCloudSceneLayer.SetFilters(filterDef.ToCIM());
var filters = pointCloudSceneLayer.GetFilters();
PointCloudFilterDefinition fdef = null;
if (filters.Count() == 0)
fdef = new PointCloudFilterDefinition()
//7 is "edge of flight line" - exclude
ClassFlags = new List<ClassFlag> {
new ClassFlag(7, ClassFlagOption.Exclude) }
else
fdef = PointCloudFilterDefinition.FromCIM(filters);
//keep any include or ignore class flags
var keep = fdef.ClassFlags.Where(
cf => cf.ClassFlagOption != ClassFlagOption.Exclude).ToList();
keep.Add(new ClassFlag(7, ClassFlagOption.Exclude));
fdef.ClassFlags = keep;
//apply
pointCloudSceneLayer.SetFilters(fdef.ToCIM());
